1992,Lt1,car is running bad during cold start.Then check engine light comes on.The analog temp gauge quit working also.Weve switched sensors and still get check engine light.any ideas
Welcome to the Forum!!!!!!! For questions about your C4 just head over to the C4 General Forum and ask the members who own them. Best of luck, enjoy the Forums.
Which sensor did you replace ? The ECM reads the CTS which is front/left side of engine (water pump)--that is the circuit which would set code 15. Welcome to the Forum
