89 Vette
Old Mar 5, 2011 | 11:34 AM
Thedeckster's Avatar
Thedeckster
3rd Gear
Default 89 Vette
Purchased my first corvette last year in February when I retired, always wanted one. It was a show car, unfortunately on the way home, it just died. After trying to figure it out all year by rebuilding items I felt it was associated with, found it may be what is called vehcile anti-theft system module. I just can't seem to figure out where it is. If anyone can help, would be appreciated. Like to drive it and start showing it again someday!
Old Mar 5, 2011 | 12:02 PM
csexton's Avatar
csexton
Welcome
Chuck
Old Mar 5, 2011 | 12:08 PM
RicK T's Avatar
RicK T
Welcome to the Forum!!!!!!! Congratulations on your C4!! Sorry to hear you've had so much trouble. Just head over to the C4 General Forum for help from the guys who own them and know them best. Good luck, enjoy the Forums.
http://forums.corvetteforum.com/c4-g...discussion-34/
Old Mar 5, 2011 | 12:28 PM
Thedeckster
3rd Gear
Old Mar 5, 2011 | 01:09 PM
gilhuly's Avatar
gilhuly
welcome to the forum
Old Mar 5, 2011 | 03:26 PM
TN 2005 C6's Avatar
TN 2005 C6
Cruise-In VI, VII & XII Veteran
St Jude Donor '07-'08-'09
Welcome aboard. Hopefully the guys in the C4 Sections will help you get your Corvette running.
Old Mar 5, 2011 | 04:39 PM
guappy's Avatar
guappy
Welcome to the forum
Old Mar 5, 2011 | 05:20 PM
jsls0130's Avatar
jsls0130
Welcome to the Corvette Forum.
Old Mar 5, 2011 | 06:49 PM
traindude's Avatar
traindude
Welcome aboard!
Old Mar 5, 2011 | 08:05 PM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
Welcome to the forum..
Old Mar 5, 2011 | 11:43 PM
mrmtrtrnd's Avatar
mrmtrtrnd
Welcome to the Forum and good luck with that problem
Old Mar 6, 2011 | 02:14 AM
ZR-71's Avatar
ZR-71
St. Jude Donor '15
Welcome and congrats on your Vette
A couple things come to mind. If it's a stick shift, it could be the clutch switch. Also the ignition key has a resistor on it that can wear down. Try your spare key. And when you have a failed start, there is typically a 10 or 15 minute period during which the theft system will not let it start.
Good luck and as was mentioned, the C4 section can help you with your problems.
Old Mar 6, 2011 | 07:02 AM
Bills Z06's Avatar
Bills Z06
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Welcome!
Old Mar 6, 2011 | 08:10 AM
ALVetteFan's Avatar
ALVetteFan
Welcome to the Forum.
Old Mar 6, 2011 | 10:58 AM
TWISTERUP's Avatar
TWISTERUP
Try the "search" function in the C4 forums for VATS-- there are multiple threads/posts about location of components and modules--how to check,repair and bypass etc.
Old Apr 3, 2011 | 11:27 AM
vette.mix's Avatar
vette.mix
Congrats and Welcome to the best Corvette Forum
Martin
To 89 Vette
