need help with first c4 vette
Old Jun 6, 2011 | 08:53 AM
LV_c4's Avatar
LV_c4
Default need help with first c4 vette
Hello all,
First I'd like to thank the creators "Corvette forum"...well done!
Just bought 86 not running, the short story is engine turns over no pulse at the injectors but runs at idle with starter fluid.
I checked for codes but got no flash from service soon light (jumped A&B)
When I started to pull ecm found a 13 pin conector next to ecm
It matches image of vats control module harness ....but no module
Any advice would be great, unless I can find a solution to F/I pulse
was planing on carb setup
Thanks all
Old Jun 6, 2011 | 10:47 AM
RicK T's Avatar
RicK T
Welcome to the Forum!!!!!!!! I don't know anything about the C4's. The best I can offer is to refer you to the C4 Forums where I'm sure the members who own them can help you. Best of luck, enjoy the Forums.
http://forums.corvetteforum.com/c4-g...discussion-34/
Old Jun 6, 2011 | 12:39 PM
syco_cop's Avatar
syco_cop
No pulse or no fuel pressure? If no pulse check your ignition module, if no pressure check pump, pump relay.
Old Jun 6, 2011 | 04:52 PM
TN 2005 C6's Avatar
TN 2005 C6
Cruise-In VI, VII & XII Veteran
St Jude Donor '07-'08-'09
Welcome aboard. Please ask your questions in the C4 Section(s) below.
Old Jun 6, 2011 | 05:10 PM
gilhuly's Avatar
gilhuly
Congrats on your C4!
Good luck and welcome!
Old Jun 6, 2011 | 07:35 PM
Wyndridge3's Avatar
Wyndridge3
Welcome to the forum. Hope you found your answer in the C4 section. The resources available on this site are amazing
Old Jun 6, 2011 | 08:30 PM
jsls0130's Avatar
jsls0130
Hello and welcome to the Corvette Forum.
Old Jun 6, 2011 | 08:43 PM
csexton's Avatar
csexton
Welcome
Chuck
Old Jun 6, 2011 | 08:56 PM
mrmtrtrnd's Avatar
mrmtrtrnd
Old Jun 6, 2011 | 09:28 PM
guappy's Avatar
guappy
Old Jun 6, 2011 | 10:48 PM
LV_c4's Avatar
LV_c4
Thanks for all the warm welcomes!
I've followed your advice and have posted in c4 tech forum under
no vats module = no inj pulse
thanks again all!
Old Jun 7, 2011 | 10:24 AM
Bills Z06's Avatar
Bills Z06
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Welcome and good luck!
Old Jun 8, 2011 | 05:11 AM
LV_c4's Avatar
LV_c4
Thanks again for all the warmth ....glad to be here
Old Jun 14, 2011 | 12:26 AM
traindude's Avatar
traindude
Welcome aboard and Congrats!
To need help with first c4 vette
