New member...need help!
Old Aug 8, 2011 | 11:07 AM
1mcwrench49's Avatar
1mcwrench49
5th Gear
Default New member...need help!
Hello everybody!!!
I run a general auto repair shop here in N.C., and have a couple of customers with vintage Vettes....all of them sharp cars. Sometimes I run into a little difficulty getting repair info on them....and I've run into that very problem now.
I've got a 1980 vette here with an ac/ vent heater door problem. I've narrowed down the problem to the vaccuum switch on the a.c controller being bad. I got a new(?) one from Eckler's, but it won't pull any vacuum through either. I can hook vacuun to the port for the black line, and none of the other ports gets vaccuum when I switch it....it's bad....right?
I've also noticed that the vent doors (which do work if I apply vacuum to the connector) do not seem to be opening and closing when they're supposed (when the switch does work occasionally). If somebody has the vaccuum diagram or a pic of the ac/ heater system controls, I would deeply appreciate the info.
Old Aug 8, 2011 | 11:22 AM
Kennethbuck's Avatar
Kennethbuck
Originally Posted by 1mcwrench49
Hello everybody!!!
Welcome to the forum! This forum is broken down into general and specific help, and by type of vette you own. I would ask you to refer your question to the C3 Tech forum here, there are some very knowledgeable members here, I've always gotten my questions answered pretty quickly.
Old Aug 8, 2011 | 11:39 AM
1mcwrench49
5th Gear
thanks!
Old Aug 8, 2011 | 01:47 PM
TN 2005 C6's Avatar
TN 2005 C6
Cruise-In VI, VII & XII Veteran
St Jude Donor '07-'08-'09
Welcome aboard.
Old Aug 8, 2011 | 02:26 PM
jsls0130's Avatar
jsls0130
Hello and Welcome to the Corvette Forum.
Old Aug 8, 2011 | 02:32 PM
dadvan99's Avatar
dadvan99
Cruise-In VII Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Oldtimer
Hello and welcome to the forum from NE Ohio.
I found this thread in the C3 Tech/Performance section that has reference to a 1980 with a 1977 diagram. Check out post #32 in this thread. Good luck.
http://forums.corvetteforum.com/c3-t...8-vette-2.html
Old Aug 8, 2011 | 11:05 PM
traindude's Avatar
traindude
Welcome aboard!
Old Aug 9, 2011 | 02:09 AM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
Welcome to the forum..
Old Aug 9, 2011 | 05:31 AM
csexton's Avatar
csexton
Welcome
Chuck
Old Aug 9, 2011 | 08:56 AM
Bills Z06's Avatar
Bills Z06
Welcome!
Old Aug 9, 2011 | 08:11 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
Welcome aboard!
Old Aug 12, 2011 | 05:49 PM
mrmtrtrnd's Avatar
mrmtrtrnd
Welcome to the Forum
Old Aug 13, 2011 | 07:46 AM
guappy's Avatar
guappy
Old Aug 13, 2011 | 05:59 PM
K.Shupe's Avatar
K.Shupe
St. Jude Contributor
Can't help with the diagram, but welcome to the Forum
To New member...need help!
