P1416
Old Feb 18, 2012 | 04:19 AM
Bruce Schilling's Avatar
Bruce Schilling
5th Gear
Default P1416
I have an 03 and I'm getting the check engine light. Using the OBD/ DIC, I see the P1416 code but I don't think it the check valve. The pump itself is not running when starting cold.! I'm not getting the trouble code for the pump only the check valve. I cleared the code, started the car, ran it around the block turned it off and checked for codes, No PCM codes. Went for longer ride (15 miles) check for codes and had the p1416 code. could it possibly be the O2 sensor? If so where is it?
Also:
Does anyone know of a way I can determine if the pump is dead or if its a control problem. How do you get to the pump? Do I have to remove the headlight assy? or the entire nose.
Old Feb 18, 2012 | 07:03 AM
mrmtrtrnd's Avatar
mrmtrtrnd
Welcome to the Forum Bruce and the best place to get answers would be C5 General or Tech. Those guys will help with that, good luck
Old Feb 18, 2012 | 07:30 AM
Bills Z06's Avatar
Bills Z06
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Welcome and good luck!
Old Feb 18, 2012 | 09:12 AM
MacC608Vette's Avatar
MacC608Vette
WELCOME TO THE FORUM FROM LOUISIANA
Old Feb 18, 2012 | 09:45 AM
gilhuly's Avatar
gilhuly
welcome to the forum!
try this site for your problems and good luck....
http://forums.corvetteforum.com/c5-general-103/
Old Feb 18, 2012 | 09:53 AM
VETJAZZ's Avatar
VETJAZZ
Welcome to the forum!
Old Feb 18, 2012 | 11:16 AM
RicK T's Avatar
RicK T
Welcome to the Forum!!! Enjoy.
Old Feb 18, 2012 | 01:33 PM
Vette_DD's Avatar
Vette_DD
Welcome to the forum. I'm sure those C5 General folks can help you with just about anything.
Old Feb 18, 2012 | 03:23 PM
Todds427's Avatar
Todds427
St. Jude Donor '12
Welcome!
Old Feb 18, 2012 | 09:01 PM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
Welcome to the forum..
To P1416
