I have a 1989 C-4 and can't get it started, although I have never had this problem before. I keep it in storage and crank it 1 to 2 times a month and bring it up to temp. Added 5 gal. new fuel and it cranked fine. The next wk. tried to start but won't and hasn't started since. Fuel pressure is ok, new fuel filter, new fuel sending unit, firing ok. Any suggestions would be greatly appreciated. P. S. I can remove the air induction and spray fuel in and it will run until it burns out, then nothi ng.
Reason: delete
