Need Help with 1971 Stingray
Old Nov 8, 2012 | 09:47 PM
Christa's Avatar
Christa
6th Gear
Default Need Help with 1971 Stingray
Hello, All,
Just signed up tonight and could you use some help - I have a 1971 Stingray -454 - convertible. I owned the vehicle since July 2000 - this is the vin # 194671S116091 (which is within the vin numbers for the 1971 production with the 4th digit being a 6 indicating it is a convert) the numbers stamped on the engine are T0319CPH with a bit smaller number listed (again, stamped) C11S116091 On the door the tag number is 130 - trim 412 and paint 979
OK - I get that it was built in T town on March 19 and the trim and paint are blue my question is what does the 130 on door tag stand for (I read that because of the strike sometimes a letter wasn't used but a number for the month)? Also the smaller number matches the vin from "1S116091" but what does the C1 stand for.
I have read that there was a strike so some of the engine numbers had a "alpha C" in them for the 1971 year but have no clue what that means - does the engine match the vehicle? I was told 12 years ago that it did but never thought to check this out.
Any and all help is greatly appreciate!
Christa
Old Nov 9, 2012 | 04:28 AM
cor28vettes's Avatar
cor28vettes
Default Welcome to the CF
Might be best to ask the moderator to send it over to C3 General Discussion after it has run its course here. Unless someone has the answer on the Intro forum. C3 guys there are familiar with your C3.
To alert the moderator just click the small red triangle under your Avator and make the request of venue change.
Old Nov 9, 2012 | 06:17 AM
dahogan's Avatar
dahogan
Enjoy while you can.
Ohio Events Coordinator
2025 Corvette of the Year Winner - Unmodified
St. Jude Donor '14 thru '26
welcome aboard and ask your question here:
http://forums.corvetteforum.com/c3-general-119/
Old Nov 9, 2012 | 06:37 AM
Bills Z06's Avatar
Bills Z06
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Welcome!
Old Nov 9, 2012 | 08:22 AM
mrmtrtrnd's Avatar
mrmtrtrnd
Welcome to the Forum Christa and good luck with that
Old Nov 9, 2012 | 09:25 AM
gilhuly's Avatar
gilhuly
Welcome and good luck with your Stingray Christa!
Old Nov 9, 2012 | 06:02 PM
Christa's Avatar
Christa
6th Gear
Thank you for the warm welcome!
Old Nov 11, 2012 | 08:32 AM
guappy's Avatar
guappy
Welcome
To Need Help with 1971 Stingray
