RPM Tachometer conversion
Old Jun 9, 2013 | 03:54 AM
alkhoory's Avatar
alkhoory
7th Gear
Default RPM Tachometer conversion
I own a 1969 Corvette C3 and I recently converted the old 454 Big Block to a LS2 engine but the rpm gauge stopped working. I was told by the mechanic that I need to convert the rpm tachometer so it can adapt to the new system (ECU). I need help with the conversion for the rpm and what to use to connect it straight into the ECU, because when connecting it to HP Tuner, the rpm works fine, it's just the gauge. Thanks.
Old Jun 9, 2013 | 10:21 AM
mrmtrtrnd's Avatar
mrmtrtrnd
Welcome to the Forum. You could check in the C3 section and see if anyone there can help
Old Jun 9, 2013 | 04:43 PM
gilhuly's Avatar
gilhuly
Good luck and welcome to the forum!
Old Jun 10, 2013 | 05:27 AM
kedwin's Avatar
kedwin
Welcome to the forum!
Old Jun 10, 2013 | 09:44 AM
alkhoory's Avatar
alkhoory
7th Gear
Thanks guys, will do.
Old Jun 10, 2013 | 04:40 PM
42Chevy's Avatar
42Chevy
It's 5 o'clock Somewhere
St Jude Donor '13-'14-'15
Good luck. Welcome to the forum!
Old Jun 11, 2013 | 07:06 AM
Bills Z06's Avatar
Bills Z06
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Welcome!
To RPM Tachometer conversion
