Is the C3 A/C Compressor Leaking?
Old Aug 7, 2013 | 11:44 AM
Ely's Avatar
Ely
Default Is the C3 A/C Compressor Leaking?
My C3 corvette (’78) air conditioning compressor is thought to be leaking. I believe it is a R4 style compressor. See picture below. Some compressors have a welsh plug in this area replacing the circlip that is pictured.
Just to the right of the blue cap (in the center of the photo) & to the left of the ground wire, you can see some of the greenish leak detection dye that has accumulated. The system is curently operational, but I believe that it is only a matter of time until the 134a leaks out.
I think this is just a matter of replacing the current "O" ring with a new 134a compatible “O” ring. Note that this is a retro from the original R12 system. I’m suspicious that the current “O” ring was overlooked in the retro process and now needs replacing.
Am I overlooking something, or is this just a matter of taking down the system, replacing the current “O” ring, and recharging it with 134?
Old Aug 7, 2013 | 12:31 PM
dahogan's Avatar
dahogan
Enjoy while you can.
Ohio Events Coordinator
2025 Corvette of the Year Winner - Unmodified
St. Jude Donor '14 thru '26
try asking here:
http://forums.corvetteforum.com/c3-tech-performance-3/
Old Aug 7, 2013 | 06:01 PM
427 Pilot's Avatar
427 Pilot
Good Luck with repair!
Welcome to CF
Old Aug 7, 2013 | 06:13 PM
mrmtrtrnd's Avatar
mrmtrtrnd
Welcome to the Forum and good luck with that issue
Old Aug 7, 2013 | 09:04 PM
guappy's Avatar
guappy
Welcome to the forum
Old Aug 7, 2013 | 10:25 PM
Ely's Avatar
Ely
Originally Posted by dahogan
Thanks Dahogan. I moved the post to the C3 Tech.
Old Aug 8, 2013 | 06:50 AM
Bills Z06's Avatar
Bills Z06
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Welcome and good luck!
Old Aug 8, 2013 | 06:59 AM
kedwin's Avatar
kedwin
Welcome to the forum!
Old Aug 8, 2013 | 07:30 AM
gilhuly's Avatar
gilhuly
welcome to the forum!
To Is the C3 A/C Compressor Leaking?
