Would this work?
Old Sep 28, 2013 | 10:39 AM
Kodster327's Avatar
Kodster327
3rd Gear
Default Would this work?
I have a Gen 1 350 small block that is bored .60 over. I am getting new 1.5 ratio rocker arms and i am wanting to upgrade my cam that is in it. The one i am looking at has Duration at 050 inch Lift: 246 int./246 exh, Advertised Duration: 302 int./302 exh., Valve Lift with Factory Rocker Arm Ratio: 0.500 int./0.500 exh.
Lobe Separation (degrees): 106. My question is would this cam work with stock valve springs. If not what would anybody recommend getting for the upgraded springs? And what other work would need to be done? I believe the guy at the machine shop said that the heads where 882's or something very similiar to those numbers.
Old Sep 29, 2013 | 09:33 AM
gilhuly's Avatar
gilhuly
welcome to the forum!
Old Sep 29, 2013 | 10:14 AM
Kodster327's Avatar
Kodster327
3rd Gear
Thank you!
Old Sep 29, 2013 | 12:22 PM
mrmtrtrnd's Avatar
mrmtrtrnd
Welcome to the Forum and I don't have a answer to that question. I think you need to check out one of the Tech forums here and ask the guys that know this stuff
Old Sep 30, 2013 | 07:28 AM
kedwin's Avatar
kedwin
Welcome to the forum!
Old Oct 2, 2013 | 07:40 PM
427 Pilot's Avatar
427 Pilot
Welcome to CF
To Would this work?
