I was on a trip to Pinehurst this weekend and noticed that the drivers side headlight housing was not fully down when lights off, it was up about an inch.
I operated the headlight switch and watched the right side go up and the left side go up and then go down it seems whatever position I ask the lights to do the drivers side (Left) does the opposite but not ever fully up or down.
I have tried adjusting the manual **** on the motor but still not getting full travel either way.
You have either a C2, C3, C4 or a C5. Go to the appropriate section here in the forum and ask your question there. You might also use the search function for an answer there too. Good luck
