C4 right front fender replacement
Old Oct 13, 2014 | 09:38 AM
vetteboy04's Avatar
vetteboy04
1st Gear
Default C4 right front fender replacement
Do new fiberglass body panels come pre-drilled for screws into frame? Had right front fender panel replaced not long ago. Now passenger door does not open occasionally because panel prevents full door swing. It looks as if corner of panel under frame is not pulled in far enough. Help?
Old Oct 13, 2014 | 09:52 AM
gilhuly's Avatar
gilhuly
welcome to the forum!
The fine folks over in the C4 section of the forum can help. Good luck!
Old Oct 13, 2014 | 10:35 AM
dahogan's Avatar
dahogan
Enjoy while you can.
Ohio Events Coordinator
2025 Corvette of the Year Winner - Unmodified
St. Jude Donor '14 thru '26
Good luck
https://www.corvetteforum.com/forums...discussion-34/
Old Oct 13, 2014 | 11:56 PM
2010BlueGS's Avatar
2010BlueGS
Welcome to the forum from So Cal !!!
To C4 right front fender replacement
