77 tracking problem
Old Nov 8, 2014 | 04:19 PM
kessroberts1's Avatar
kessroberts1
4th Gear
Default 77 tracking problem
hi guys i am new to this site and looking for a suggestion on suspension. just had everything mechanical redone the whole 9 yards car runs like brand new.however its not tracking in a straight line the passenger rear wheel looks as if its cocked out sideways not up and down.its chewing that tire up badly opposite tire is fine.the car also hops going over bumps any suggestions would help thanks kess
Old Nov 9, 2014 | 12:00 AM
JW3101's Avatar
JW3101
St. Jude Donor '11-'12-'13-'14-'15-'16-‘17-‘18
Welcome to the forum!
You're best bet is to post this question in the C3 Tech & Performance sections as you will get more responses. Could be you need a four wheel alignment or the camber is off and needs to be adjusted or trailing arms replaced/shims need to be replaced. Good luck and congrats!
Old Nov 9, 2014 | 12:18 AM
2010BlueGS's Avatar
2010BlueGS
Welcome to the forum from So Cal !!!
Old Nov 9, 2014 | 10:48 AM
gilhuly's Avatar
gilhuly
good luck and welcome to the forum!
To 77 tracking problem
