Hello from Alaska
Old Jan 29, 2015 | 10:29 PM
SparkinAK's Avatar
SparkinAK
4th Gear
Default Hello from Alaska
Hey there.... I joined to do research, ask some questions, and mostly learn. I do not have a corvette how ever I was recently asked by a friend to assist him with his 66 Stingray roadster. It currently has a BB in it, with side pipes. The top is white, but trashed and frame is bent, so I will be replacing that. He wants an LS3 put in it connected to I'm guessing muncie 4spd. I'll be adding PS, A/C and updating the suspension and brakes. Maybe a couple other odd and ends that come up along the way. There was already confusion on the numbers on the pad, so I'm not even going to mess with that issue after reading in here for a bit. Once I get the car here I am going to make sure I know what it is and find all these labels and tags I keep reading about. After that then I will start taking it apart to do bring it up to where he wants it. I am open to suggestions and feedback however I am just doing what the actual owner wants...
Old Jan 30, 2015 | 07:47 AM
dahogan's Avatar
dahogan
Enjoy while you can.
Ohio Events Coordinator
2025 Corvette of the Year Winner - Unmodified
St. Jude Donor '14 thru '26
Good luck and those old farts in the C1 & C2 section should be able to answer any questions.
Old Jan 30, 2015 | 12:50 PM
gilhuly's Avatar
gilhuly
welcome to the forum!
Old Jan 30, 2015 | 02:05 PM
dadvan99's Avatar
dadvan99
Cruise-In VII Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Oldtimer
Hello and welcome to the forum from NE Ohio.
Old Feb 1, 2015 | 08:58 AM
guappy's Avatar
guappy
Welcome and Good Luck with the 66
Old Feb 3, 2015 | 01:37 AM
2010BlueGS's Avatar
2010BlueGS
Welcome to the forum from So Cal !!!
To Hello from Alaska
