Headlights & Interior Lights
Old Jun 5, 2015 | 11:28 PM
dpappas's Avatar
dpappas
6th Gear
Default Headlights & Interior Lights
Hey guys, new to the forum here. Just purchased a 2002 C5Z. There are quite a few electrical issues.
1. The pop up headlights opened up and the lights worked fine. They would not return down, so I manually put them back down. Now they will not go up or down.
2. This one is very confusing to me. The interior lights (dash & speedo, door lights and everything) do not work when the car is in ACC mode or when the engine is on. When I try to adjust the stalk to increase the brightness on the interior lights I get nothing. When I turn it all the way right to the click - the floor lights and rear lights do come on.
When the key is turned all the way to the left as if you were about to pull it out of the ignition- all the lights illuminate (driver and pass door panel lights, speedo, everything)
I have checked fuses and so far they all are in working order and none have blown. Has a new battery as well.
Any ideas or suggestions? I am starting to think its a wire connection somewhere - bad ground or something along those lines.
Old Jun 5, 2015 | 11:44 PM
Vette_DD's Avatar
Vette_DD
Post a thread about it here:
https://www.corvetteforum.com/forums...discussion-49/
They'll help you.
Old Jun 6, 2015 | 12:40 AM
dpappas's Avatar
dpappas
6th Gear
They'll help you.
Thank You!
Old Jun 6, 2015 | 05:57 AM
kedwin's Avatar
kedwin
Welcome to the forum!
Old Jun 6, 2015 | 10:17 AM
gilhuly's Avatar
gilhuly
good luck with your car and welcome to the forum!
Old Jun 7, 2015 | 08:28 AM
guappy's Avatar
guappy
Welcome
To Headlights & Interior Lights
