Lt4 stroker
Old Nov 24, 2015 | 11:39 PM
Lakeratiam's Avatar
Lakeratiam
1st Gear
Default Lt4 stroker
Hi all....noob here.....I'm in the process of piecing together a lt4 396 stroker motor...I have the short block assembly done, the heads and intake (true lt4) are off to be worked over and ported....I recently found a set of composite valve covers but there is no hardware.... I've tried finding it on line but haven't had any luck. Is there an alternative to the stock hardware I can use as the stock hard seems to be about impossible to find? Any suggestions would be appreciated...Thanks.😎
Old Nov 25, 2015 | 09:28 AM
gilhuly's Avatar
gilhuly
welcome to the forum!
try using the SEARCH button and put in Stroker motor as your subject.
good luck!
Old Nov 25, 2015 | 02:31 PM
jehuds10's Avatar
jehuds10
Welcome aboard!
Old Nov 25, 2015 | 06:40 PM
NorthernProducer's Avatar
NorthernProducer
Welcome!
To Lt4 stroker
