Hello all from NZ. Wiper wiring?
Greetings everybody from down under.
May I say what a great place this is. Amazing source of expertise and sharing of knowledge.
My first v8 purchased is this 1981 C3 which had a diff leak and a few electrical items not working. First job was removing the rear bits and replaced pinion seal. Whilst there I sandblasted/buffed and painted all components, replaced rear shocks and all bushings.
Then removed/replaced steering column to solve the horn grounding fault.
Now my wipers won't work...have done research on the forum and indicators are I have a grounding issue here.
Presently removing the speedo cluster to access the wiper switch wiring.
Have seen reference to jumping a yellow to brown wire to bypass the wiper controller as a test but no idea where to do this.
Any suggestions would be greatly appreciated
Cheers Richard
Cheers Richard
hello Richard and welcome to the forum!
in case you haven't found it, heres a better place for your C3 questions.
https://www.corvetteforum.com/forums/c3-general-119/
good luck with your car and enjoy the forums!
