You have come to the right place for information. Quite a bit can be found using the search function and reviewing the various subsections of the forum. If you cannot find what you need then just post a question in the appropriate section.
Extended Big Block Hood installed in 1985, never painted. Rest of the car was repainted before that. The paint job is terrible. Wiper door and cowl panel removed, but I have them as well as the hinge and original hood, but no actuator or other hardware. The top was left down for the past 8 years or so, so it most likely wont stretch enough to latch at both ends. We will take a heat gun to it and see if we can get it to do so.
80's era ugly.
Original distributor swapped out for Mallory with no tach drive. High Energy 280H cam. Edelbrock manifold and Holley Double Pumper carb.
All of the lines are covered with braid. More 80's era ugly IMO.
