Looking for 1st corvette
Jul 3, 2017 | 01:30 PM
Hi all... I am a new member to this forum and I am looking at buying my first Corvette! Presently with budget considerations the C6 is the Corvette generation that I loooking at. I would appreciate any help and advice that you could give me! Thanks!
Jul 3, 2017 | 01:33 PM
Welcome to the CF!
Jul 3, 2017 | 01:40 PM
Thanks!
[QUOTE=AE Guy;1595069451]Welcome to the CF!
[/QUOTE
any tips?
Jul 3, 2017 | 01:48 PM
[QUOTE=Dhoehl;1595069493]
Quote:
Originally Posted by
AE Guy
Welcome to the CF!
[/QUOTE
any tips?
Sure. If you really want a C6, hang out and read threads in the C6 General Section of the forum.
If you aren't quite sure which generation Vette you want, go to dealerships and drive a C6 and drive a C5. There are pros and cons to both generations, but if you can afford a C6, then you can certainly afford a C5. I would not focus on a C6 just because I could afford one, you may find that you like the differences in the C5 better.
Jul 3, 2017 | 02:03 PM
Thanks again
Thanks for the tip! Yes I believe a test drive is in order !
Jul 3, 2017 | 07:09 PM
Ohio Events Coordinator
2025 Corvette of the Year Winner - Unmodified
St. Jude Donor '14 thru '26
[QUOTE=AE Guy;1595069559]
Dhoehl
Be patient and do your homework and the outcome will be much better.
Jul 3, 2017 | 07:12 PM
St. Jude Donor '17 thru '26
Dhoehl
Jul 3, 2017 | 07:19 PM
As said earlier - the C6 sections of the forum will have a lot of valuable info for you to use in your search for your car.
Jul 3, 2017 | 07:26 PM
Great advice! Thanks!
Jul 4, 2017 | 08:33 PM
good luck in your search and welcome to the forum!
Jul 4, 2017 | 09:45 PM
Welcome to the forum!
Good luck in your search!
Be sure to check out both the C5 and C6 areas for information, both are now reaching reasonable, affordable pricing for many prospective new owners.
Jul 5, 2017 | 08:47 AM
Jul 5, 2017 | 01:41 PM
Welcome. Mid to low 20's will get you into a low mileage C5 or an early C6 (pre 2008) so as suggested I would test drive both.
Jul 5, 2017 | 09:40 PM
JEH03Vette
Thanks for your reply!
