C6 Fuel System
Old Aug 3, 2017 | 01:59 PM
f1vette's Avatar
f1vette
Navigator
Default C6 Fuel System
I have a complete 2012 C6 drop out that I am installing into a custom application. In a stock LS3 such as this, the fuel pressure regulator is in the tank and it is completely mechanical regulator. There does not appear to be any pressure sensing in the fuel system for the purpose of cycling the pump on and off. My question is, does the fuel pump in this system run continuously? (I know the LS9 version utilizes a pressure control system and varies pump output accordingly. My system does not appear to be equipped with this.)
My plan is to utilize the stock fuel pump with after market external regulator/filter/return(58psi). I am trying to figure out the wiring to the pump. Right now it appears to me all I need is fused/ignition-on hot wire to the pump. Is this correct? Thanks much for replies.
Old Aug 3, 2017 | 02:06 PM
FX VETTE's Avatar
FX VETTE
You posted this in the Intro section (welcome to the CF by the way). You will get better responses once this thread makes it to the C6 section. You could wait for a Moderator to happen along and move it for you or you can message a Moderator and ask them to move it.
Old Aug 3, 2017 | 02:11 PM
dahogan's Avatar
dahogan
Enjoy while you can.
Ohio Events Coordinator
2025 Corvette of the Year Winner - Unmodified
St. Jude Donor '14 thru '26
Try posting your question here:
https://www.corvetteforum.com/forums...rformance-101/
Old Aug 3, 2017 | 04:13 PM
This has already been posted in the C6 Tech section. Closing this thread.
To C6 Fuel System
