05 Rear End
Old Oct 25, 2017 | 03:13 PM
boostman94's Avatar
boostman94
Cruising
Default 05 Rear End
hello, i’m new to the forums. i recently purchased an 05 automatic base corvette. i have t trim supercharger on the way and texas speed long tube headers. i also have full set of m/t street r drag radials ready to put on her. i know i will need to upgrade the rear end because it will not be able to hold as much power as i’ll be putting into her. what’s the best option when it comes to getting a better rear end?
Old Oct 25, 2017 | 03:49 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Congrats and welcome to the forum Boost!
The best place to ask your question is in the C6 section.
Good Luck!!
Old Oct 25, 2017 | 03:56 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Welcome to the Forum!
Several vendors including Spartan, A&A, RPM, Vengeance and probably others can help with your trans/differential build up. As Jeff suggested you'll find lots of good info in the C6 section about these and other vendors.
Good luck with your work.
Old Oct 25, 2017 | 03:57 PM
boostman94's Avatar
boostman94
Cruising
appreciate it guys!
Old Oct 25, 2017 | 05:28 PM
This has already been posted in C6 General.
To 05 Rear End
