New member
Feb 20, 2018 | 04:42 PM
New member
Hello to all,
I am working on a customer's Corvette and have had many questions. It is a 1971 LS5 4 speed car that has been sitting for three decades. Someone has added after market AC to the car. Things we have encountered so far, that I have found the answers for here are as follows. Having trouble getting the gas tank filler centered in the gas door. Solution bend the tank seam at straps and install the tank correctly. This car has a radiator cap and surge tank cap, not correct but does not seam to be a concern. PS belt way out of alignment, solution wrong alternator pulley. 5/8 inch water pump shaft with 3/4 inch shimmed pulley. Ordered another 5/8 inch pump but it was too short. 3/4inch Delco 252-303 pump solved that. May have been rebuilt incorrectly? We started it last week and all is good. Many more projects on his list so I will more likely than not I will be checking in often. Thanks for the help! John
Feb 20, 2018 | 05:05 PM
Ohio Events Coordinator
2025 Corvette of the Year Winner - Unmodified
St. Jude Donor '14 thru '26
Welcome aboard and I hope those guys in the C3 section continue to help you out. Good luck on the restoration
Feb 20, 2018 | 05:10 PM
St. Jude Donor '06 thru '26
Quote:
Originally Posted by
dahogan
Welcome!
Feb 20, 2018 | 05:50 PM
St. Jude Donor '17 thru '26
Welcome to the forum!
dahogan has you pointed to the best section of the forum to get assistance with your efforts.
Best wishes
Feb 20, 2018 | 06:08 PM
Good luck with the rest of your project!
Feb 20, 2018 | 06:17 PM
Welcome to the Corvette Forum John. Good luck with the LS-5.
Feb 20, 2018 | 06:44 PM
Welcome and please post any questions you may have on repairing the car in the C3 Tech/Performance Section of the forum. Good luck getting it fixed.
Feb 20, 2018 | 07:05 PM
St. Jude Donor '13 thru '26
Welcome to the forum John!!
Feb 20, 2018 | 07:57 PM
Welcome to the CF!
Feb 20, 2018 | 09:16 PM
Thanks! I spent years on V8Buick.com building a 1971 Skylark convertible so hopefully I get my posts in the correct section.
Feb 21, 2018 | 06:50 AM
Hello John and welcome to the forum!
Feb 21, 2018 | 11:22 AM
