Welcome to the forum and congratulations on your sharp, very low mileage Z06!
Hang in there. Any new forum is probably challenging the first few times but then will start making more sense. Your first pic came through fine.
This link will take you to the C7 section of the forum. https://www.corvetteforum.com/forums/c7-corvette-141/
Best wishes
Best wishes
Welcome to the forum and fine looking Z06 you have. If you do experience more difficulties in traveling the forum, try posting your questions in the Help Section https://www.corvetteforum.com/forums/help-forum-31/ and someone there will guide you through the process.
Congrats and welcome to the forum. As others have said, this is a good forum but you should spend some time perusing each section so you know what is here. You will spend a lot of time in the C7 section, and possbily in some of the others such as General Corvette, which includes car care, electronics, wheels and tires, etc. The Sticky sections have good information to and you should find the ones that describe various things about the C7. Also, use the search function.
