Purchased a 1989 convertible in November. Working on pics. It sat for three years outside with a "sometimes cover". Was able to drive it home and park it in a heated garage for the winter. Haven't had any time to play with it until a few weeks ago. Pushed through some new brake fluid...now it stops. Ran some fuel through it, and it ran better and better....until it doesn't run? Another story for another day.
Thanks to you'll for the posts that I've read so far.
Welcome to the forum.
If you can't figure out a solution to the car's problems, post up your questions in the C4 Tech section - lots of good info and helpful members over there.
I'll be full of questions, when I understand what to ask. There is a lot of basics to sort first. When I touch a vacuum line, it falls apart in my hand, wires damaged by the lambo door install, interior lights always on. Radio turns itself on. Corroded connections. Security confused sometimes...when I press the horn. Fun stuff, but I knew this when I bought it. When I figure out where to start, I'll be asking. Until then, I am enjoying what has been posted and learning from that. And maybe I can contribute to the forum along the way.
