Check Engine light
Check Engine light
In order to pass the California smog test my check engine light must go on when you turn on the ignition. I passed the test except for the fact that the engine light won't go on. The bulb and the fuse are good. Any ideas why the light won't go on. Thanks.
Received 1,090 Likes
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Robert, in order to point you in the right direction we need more info. Year of the car would really help to get you in the right section.
St. Jude Donor '17-‘18-'19-'20-'21-'22-'23-'24
Welcome to the forum, Robert!
As Jeff T pointed out more info is helpful.
You may want to post your question in the General section of whatever generation Corvette you are having this issue with. (See top left under Forums).
Best wishes for an easy fix.
Received 19,307 Likes
'20-'21-'22-'23-'24
Instead of posting in the appropriate General section, post up the details and question in the appropriate Tech section. Closing this thread.
