New from Florida (central)
Old Jun 12, 2018 | 11:19 AM
82cevert's Avatar
82cevert
2nd Gear
Default New from Florida (central)
Hello,
I've been a member before but kinda lost interest in my ce c3. i've had a lot of problems and have a renewed interest in working on it. currently it is not running and no 12v to the distributor. i have a new ignition switch i plan to install this weekend and hope that solves the problem.
it started out where the fuse link burned to the starter, replaced that ran for a while and ended up at the shop with a new engine harness. got it back and ran fine for a couple days then started shutting off on me. with the help of users here i was able to determine that the fuel pump relay works, fuel pump works, bypassed the oil pressure switch to check fuel pump. currently when i turn the key to the run position there is not 12v at the distributor, no turn signals, no gauges and will not start. I hard wired the distributor and blinkers work, gauges work so my problem is no 12v from the switch. i got really frustrated dumping money in it and thanks to CorvetteBen I was able to refresh my interest and to try and tackle the problems myself.
it has been fun but checking fuses and crawling around the tight spaces in this car can be challenging.
anyway wanted to introduce myself, i'm mike and i bought my 82 back in 2010 and have only been able to drive it about a dozen times. it has just under 80K and will post some pics soon. i'm the third owner and was hit in the back while the first owner had it so the car has been repainted back to original color but has no decals. inside and out it's in decent shape.
thanks for reading,
Old Jun 12, 2018 | 03:39 PM
Welcome and good luck getting all the problems sorted out with your C3.
Old Jun 12, 2018 | 04:43 PM
Jstan2014's Avatar
Jstan2014
Welcome back Mike. Good luck with your 82 CE C3!
Old Jun 12, 2018 | 07:01 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Welcome back to the forum, Mike.
Hope your repairs are simple, easy and inexpensive!
Old Jun 12, 2018 | 08:18 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
Welcome back!
Old Jun 12, 2018 | 08:38 PM
FX VETTE's Avatar
FX VETTE
Welcome to the CF!
Old Jun 12, 2018 | 09:16 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Welcome to the forum Mike!!
Hope you get your issues sorted!
Old Jun 13, 2018 | 06:04 AM
jehuds10's Avatar
jehuds10
Welcome to the forum!
Old Jun 13, 2018 | 06:29 AM
82cevert's Avatar
82cevert
2nd Gear
Default Thanks
thank you all for the warm welcome and best wishes
Old Jun 13, 2018 | 07:50 AM
rkj427's Avatar
rkj427
Pro Mechanic
Best of luck getting your C3 CE fired up and back on the road!
Old Jun 13, 2018 | 08:48 AM
gilhuly's Avatar
gilhuly
Hello Mike and welcome to the forum!
Old Jun 13, 2018 | 01:19 PM
RossDowningChevrolet's Avatar
Platinum Supporting Dealership
Welcome back Mike and good luck on that project.
__________________
MARQUIS ROBERTSON
Corvette Sales Manager
Ross Downing Chevrolet
Louisiana's #1 Corvette Dealer since 1992
985-345-1285
"PUTTING DREAMS IN DRIVEWAYS ACROSS AMERICA"
Join our Facebook Corvette community!
New Corvettes For Sale | Used Corvettes For Sale | About Us | Contact Us
[/FONT]
To New from Florida (central)
