Neutral Safety Switch
Old Jun 25, 2018 | 08:51 PM
Jaredjames1's Avatar
Jaredjames1
5th Gear
Default Neutral Safety Switch
Is there an adjustment for the neutral safety switch? I found out my 77 will still start in drive. The wires and switch are still intact, or is it something that is just replaced?
Old Jun 25, 2018 | 09:19 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Welcome to the forum!
You'll probably do better posting this question in the C3 section of the forum at https://www.corvetteforum.com/forums...s-1968-1982-5/. I'd suggest placing this in the Tech section.
Best wishes for an easy fix.
By the way, courtesy of forum sponsor Willcox Corvette here is the recommended process for Neutral Safety Switch Adjustment: http://repairs.willcoxcorvette.com/1...djustment-wat/
Old Jun 25, 2018 | 09:38 PM
Jaredjames1
5th Gear
Thank You!
Old Jun 25, 2018 | 11:17 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Welcome to the forum Jared!!
Old Jun 26, 2018 | 12:49 AM
This has been posted in the C3 Tech section.
To Neutral Safety Switch
