1st Corvette
Old Apr 27, 2020 | 09:47 AM
Hurlz's Avatar
Hurlz
Cruising
Default 1st Corvette
Dave, 1st Corvette wanted 1 for a long time.I bought a 1996 Collectors edition. Haven't used it much yet with all going on, but i have already done my fair share of wiping it down. It was basically a 50th birthday present to myself. The car has some neat upgrades like long tube headers, electric water pump. Did my 1st oil change. i have already learned a few things from this forum, also found the old owner who did most of the work, but he has not been on since 2017. Would love to ask him a few questions as he put about 30K on the car and appears to have done all the work. having troubles with the BBE mufflers working, but haven't really looked into it as they are stuck wide open.
Old Apr 27, 2020 | 10:15 AM
FX VETTE's Avatar
FX VETTE
Welcome to the CF!
Old Apr 27, 2020 | 12:43 PM
jehuds10's Avatar
jehuds10
Welcome to the forum!
Old Apr 27, 2020 | 12:51 PM
JungleCat's Avatar
JungleCat
St. Jude Donor '05 thru '26
Welcome aboard!
Old Apr 27, 2020 | 02:07 PM
Nice ‘96 you bought. Hope the car gives you many years of driving pleasure and welcome to the forum.
Old Apr 27, 2020 | 07:27 PM
SingleTrackMinded's Avatar
SingleTrackMinded
Congratulations on your C4 and welcome to the CF
Old Apr 27, 2020 | 08:52 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Welcome to the Forum, Dave, and congratulations on your sharp C4!
If you can't contact the former owner, you might reach out to BBE; they've always been good to answer questions I have.
Sounds like you have a great neighbor!
Old Apr 27, 2020 | 10:06 PM
Schiller7's Avatar
Schiller7
Happy birthday Dave! You got yourself a nice looking present. Congrats and welcome to the forum.
Old Apr 28, 2020 | 07:47 AM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Congrats and welcome Dave!!
Old Apr 28, 2020 | 08:08 AM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
Good looking CE! Congrats and enjoy, welcome!
Old Apr 28, 2020 | 10:38 AM
Hurlz's Avatar
Hurlz
Cruising
Thanks for the warm welcomes guys. Once we get some nice weather around here I will post some better pictures.
Old Apr 28, 2020 | 11:29 AM
oldpainter's Avatar
oldpainter
Welcome and enjoy your ride.
Old Apr 28, 2020 | 12:39 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Congratz! First one always the most exciting
Old May 25, 2020 | 06:46 PM
Hurlz's Avatar
Hurlz
Cruising
Haven’t done the other side splash guards yet. Wife thinks it makes the car look better. Battery cover was on wrong, fixed that, added a new set of Bilstein shocks in the rear, fronts on order ride improved. New tires last week. Getting there.
Old May 26, 2020 | 06:42 AM
mazdaverx7's Avatar
mazdaverx7
Welcome!!! That's s beautiful CE!! Is it an LT1 or LT4? The car looks to be in awesome condition!! How's the interior?
Old May 26, 2020 | 08:50 AM
gilhuly's Avatar
gilhuly
Congrats on your C4 and welcome to the forum!
Old May 26, 2020 | 01:44 PM
Hurlz's Avatar
Hurlz
Cruising
LT-4 and the interior is very nice
only interior pic I have at the moment
To 1st Corvette
Old May 28, 2020 | 05:45 PM
old stingray's Avatar
old stingray
Welcome aboard.
Old Jul 11, 2020 | 10:07 AM
Hurlz's Avatar
Hurlz
Cruising
Installed front shocks, Fixed the BBE mufflers with exhaust cut outs. What a difference the car is so much more refined when on, then wide open when off. It was a simple fix failed vacuum line took a bit to find. Next is the failed climate control module Seems 1996 with automatic Temp control is a 1 year module although 1990-96 looks same in pictures just different model numbers.
Old Dec 3, 2020 | 08:50 PM
Hurlz's Avatar
Hurlz
Cruising
Not a bad season with the car. Having no mechanic I had to fix things myself. Had to do a battery and now keep on tender, starter hot lead came loose fixed that, biggest issue was the clutch slave cylinder. It’s external so not too difficult if Zip corvette sends the right part. I did that job 3 times as the old one worked just not well and was leaking probably because it had been loose on the bell housing. Whomever worked on this car previously was not a heavy hand the oil filter spun off when I put my hand on it. But I wanted a car that was old and I thought I could work on, I like it enough, it rips pretty good and it comes apart when needed.
