rochester tripower
Old May 19, 2021 | 06:47 AM
CRUSTY-COUPE's Avatar
CRUSTY-COUPE
7th Gear
Default rochester tripower
can anybody help me with rochester specifications on a early 1 3/32 rochester tripower center and end carbs please. i cannot find a service bulletin on these. going through them and want to see if they have been messed with from factory. center carb is 7036112, end carbs have no tags but are matching. thanks geoff
Old May 19, 2021 | 07:43 AM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Welcome aboard Geoff. I'd suggest asking your question in the appropriate tech section, C2, C3. Good Luck!
Old May 19, 2021 | 10:18 AM
ledger35's Avatar
ledger35
I second that! Welcome to the forum, enjoy your stay with us!
Old May 19, 2021 | 10:23 AM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Welcome to the Forum, Geoff!
Jeff T. has you pointed the right direction. This is more of a "Hello" section and you will probably get better information from the C2-C3 members on this. https://www.corvetteforum.com/forums...-1953-1967-21/. https://www.corvetteforum.com/forums...s-1968-1982-5/
Best wishes with this!
Old May 19, 2021 | 10:36 AM
Not knowing exactly what generation of car the carbs are on, I am closing this thread. Please repost this in either the C2 Tech or the C3 tech section as appropriate.
To rochester tripower
