My First Vette
Old Sep 25, 2021 | 10:01 AM
Jowens7896's Avatar
Jowens7896
Default My First Vette
I recently got a 1986 C4 Corvette put a new fuel pump in and drove it home then it started with a crank but no start issue. Since then I have checked the fuel pressure its 42 at the rail and no drop in pressure. I put in a new fuel pump relay also. I checked Injectors with Multimeter and there within OHM Specs also with a Noid lite no Pulsing. Used Jumper wire to check codes only stored code is 46 VATS Anti theft Fault so I got vats bypass and no change in condition. So through Manual,Forum,and YouTube I decided to try the ICM since dont have spark when I use my Inline Spark Tester. My ignition coil is at almost Zero Ohms resistance. Im getting oil pressure when i crank it over. I have good ground and get battery voltage through the fuse panel. The car acts like it wants to start and every so often it would start I could drive it around then park it shut it off sometimes would start back up and sometimes it wouldn't Now for past week it wont start at all. If anyone has any ideas I dont know if ECM is my next step I dont know anyone who has one to try there's.
Old Sep 25, 2021 | 10:14 AM
Brandons72vette's Avatar
Brandons72vette
Welcome and congratulations on the C4! The C4 section will be your best place to have your questions answered! Do you have any pictures of your new ride?
Old Sep 25, 2021 | 10:18 AM
Jowens7896's Avatar
Jowens7896
Old Sep 25, 2021 | 10:19 AM
Brandons72vette
Very cool! 🙂
Old Sep 25, 2021 | 10:43 AM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Welcome to the Forum, and congratulations on your C4!
Agree with Brandons72vette that the C4 sections will be the best place for answers on your starting issue. Try posting this in the C4 Tech/Performance area: https://www.corvetteforum.com/forums...-1984-1996-19/.
You may also want to see if there are any Corvette clubs around you. You may find a skilled C4 owner who could assist you.
Best wishes for an easy and inexpensive fix!
Old Sep 25, 2021 | 04:09 PM
This is already posted in the C4 Tech section. Closing this one.
To My First Vette
