New Nube!
Old Jan 17, 2022 | 02:15 PM
LS1Zfast40's Avatar
LS1Zfast40
1st Gear
Default New Nube!
Whats up guys and ladies. I am sadly not a corvette owner. But I do have a camaro (84 Z28). I'm swapping in a L59 and T56. So my needs are essentially getting my Bin switched over to manual transmission and also getting enough of a tune to start the thing. It has a mild cam (Howards Rattler) and speed engineering long tubes. As you would guess its a stand alone harness. In my case, its a factory harness that I pared down using LT1Swaps instructions. I got rid of the cat, rear NBo2's, and anything emissions related. I hope i didnt screw it up. But really, I didnt do anything but remove stuff. I saw a kick *** post in the C5 scan and tune section about switching to a manual. Pretty comprehensive. Unreal detail. Thank you more than I possibly say!!
Old Jan 17, 2022 | 05:45 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Welcome to the Forum!
Sounds like an interesting swap. Glad you are already finding some of the information you need to help you with this. Once you are up and basically running a good tune should take care of the emissions changes you have made.
Best wishes with the remainder of your mods!
Old Jan 17, 2022 | 05:52 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
Welcome aboard!
Old Jan 17, 2022 | 06:34 PM
Welcome and good luck with your Camaro.
Old Jan 17, 2022 | 06:53 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Welcome and good luck on the switch!
Old Jan 17, 2022 | 08:14 PM
vetteish's Avatar
vetteish
Welcome to the forum
Old Jan 17, 2022 | 08:27 PM
kkupec02's Avatar
kkupec02
welcome. best of luck
Old Jan 18, 2022 | 06:35 AM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Welcome and good luck with your project!!
Old Jan 18, 2022 | 09:37 AM
gilhuly's Avatar
gilhuly
Welcome and good luck with the swap!
Old Jan 18, 2022 | 10:56 AM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Welcome
Old Jan 22, 2022 | 11:06 AM
jehuds10's Avatar
jehuds10
Welcome to the forum!
To New Nube!
