New Member
Old Mar 17, 2022 | 09:22 PM
Ceefarmboy's Avatar
Ceefarmboy
Navigator
Default New Member
I'm a new member from N.C. I have a 87 Vette and I'm seeking help with no start/electrical problems
Old Mar 17, 2022 | 09:43 PM
kkupec02's Avatar
kkupec02
welcome
Old Mar 17, 2022 | 11:10 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Welcome to the Forum from Hickory, NC, and congratulations on your C4!
This is primarily a “hello” section, so I would encourage you to post your issue in the C4 Tech section at https://www.corvetteforum.com/forums...erformance-48/. Try to provide as much detail as possible such as: has any recent work been done that might affect wiring or grounding, such as installing a new radio; have you pulled your battery and had it tested at AutoZone, Advance, or so another auto shop that can do this testing; has the car run great and this no-start problem just occurred; and anything else like this you can think of. This will help the C4 tech experts have a better understanding to try and help.
Best wishes for a simple and inexpensive fix!
Old Mar 18, 2022 | 07:17 AM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Welcome aboard and good luck getting it sorted!!
Old Mar 18, 2022 | 07:39 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Welcome!
Old Mar 18, 2022 | 09:59 AM
Welcome, but as mentioned, to get help with the problem you are having with your car, it would be best to make a thread in the C4 Tech section. Lots of knowledgeable people are there to assist.
Old Mar 18, 2022 | 12:36 PM
vetteish's Avatar
vetteish
Welcome from CLT
Old Mar 18, 2022 | 01:34 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Welcome to the Forums, this section is for greetings/intros, be sure to post in the C4 sections for more assistance
Old Mar 19, 2022 | 07:24 AM
JungleCat's Avatar
JungleCat
Welcome and good luck with the fixes!
Old Mar 19, 2022 | 08:54 AM
gilhuly's Avatar
gilhuly
Welcome to the forum!
Old Mar 20, 2022 | 07:45 PM
jehuds10's Avatar
jehuds10
Welcome aboard!
To New Member
