New Member
Old Apr 15, 2022 | 01:05 PM
Rabihhaddad's Avatar
Rabihhaddad
7th Gear
Default New Member
Hello friends
I’m Rabih Haddad from Lebanon
i have corvette c7 2014
this is my car upgrade‏C7 Engine upgrade
‏LT1 Block 416 CI Boosted
Machining racing spec preperation
Diamond -15 cc doom dished pistons 4.070"
Piston coating
Piston rings total seal GFX
Manley H beam rods 6.125
main bolts
Coated clevite bearings main
Coated clevite bearings con rods
CNC machined LT1 heads Bronze valve steam
Manly SS valves
Comp cam dual springs
Cam shaft texas speed stage 4
HD oil pump
Timing chain
Front cover new
Full Gasket Kit Felbro
Tie down lifters
push rods
Lifters guide
Rocker arms
Cam sensor
‏master kit
Head bolts
LT4 Z06 Upgraded injectors
Fuel system upgrade
‏Tourq converter stators
6L80 Transmission upgrade level 5
‏transmission upgrade
‏Oil oil filter
‏Spark plugs
‏Short travel lifters
‏Coolant
‏Transmission gear oil
‏Machinery bore and hone sleeve main line racing spec
‏Labour charger include engine rebuild trans and all required
‏Custom made Dewitt 3 core Radiator
Supercharged edelbrock e-force
Alky methanol kit c7
Old Apr 15, 2022 | 01:26 PM
Rabih - welcome to the forum. Sounds like a very nice C7 you have with some mods done to it.
Old Apr 15, 2022 | 01:44 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Welcome, and how about some pictures!
Old Apr 15, 2022 | 05:22 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Welcome
Old Apr 15, 2022 | 08:16 PM
vetteish's Avatar
vetteish
Welcome!
Old Apr 15, 2022 | 11:38 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Welcome to the Forum, Rabih, and congratulations on your C7! Sounds like some nice mods have been done!
Old Apr 16, 2022 | 08:25 AM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Welcome Rabih!!
Old Apr 16, 2022 | 09:01 AM
Rabihhaddad
7th Gear
For sure brother
Old Apr 16, 2022 | 09:49 AM
gilhuly's Avatar
gilhuly
Hello and welcome to the forum!
Old Apr 16, 2022 | 11:51 AM
jehuds10's Avatar
jehuds10
Welcome aboard!
To New Member
