Mountain - Prairie Colorado | Kansas | Montana | North Dakota | Nebraska | South Dakota | Utah | Wyoming
Help with axle back install?
Old Feb 15, 2007 | 06:28 PM
fright88's Avatar
fright88
Default Help with axle back install?
Does anyone happen to want to help me install my axle back exhaust on my C6? Anyone happen to have a jack I can borrow? LOL
Old Feb 15, 2007 | 07:09 PM
MattB's Avatar
MattB
I'm trying to get my headers done, thats the plan this weekend...
One hint is that when doing a cat back, if for some reason you want to keep the stock system you will need a lift. You have to get it very high to get the stock system out, higher than putting headers in. If you don't want to keep it, then get a sawzall and cut it. Much easier, and you don't have to lift nearly has high.
Old Feb 15, 2007 | 09:21 PM
fright88's Avatar
fright88
Yeah I am thinking I am going to have a shop install. I don't have a floor jack or a lift. And the cost of a good floor jack is about as much as having the shop install. And I'd have to rent a sawzall or buy a hack saw. Figgured I'd see if anyone happened to have the facilities (ie tools)
Old Feb 15, 2007 | 11:59 PM
TopCat's Avatar
TopCat
Do you have to lift a C6 as high as a C5 to get them out?
Old Feb 16, 2007 | 12:43 AM
Disco_Mike's Avatar
Disco_Mike
I have a floor jack and jack stands but dont the C5's, C6's sit really low to the ground.
Also, Im not sure if I can raise it high enough to remove the stock system.
Old Feb 16, 2007 | 09:03 AM
HIVLCTY's Avatar
HIVLCTY
If you decide to do it yourself instead of a shop, I have a floor jack, and stands and I'd be game to help. Unfortunately this weekend would be out, as I am tiling a room at my house . . . but just let me know if you need any help.
Old Feb 16, 2007 | 09:43 AM
fright88's Avatar
fright88
I am supposed to get it on the 21 so it wouldn't be till next weekend. I think it would be cool to do it myself but I don't want to impose either. If the weather is nice and you are up for the following weekend let me know. I can't see this being a hard install just more inconvienent without the floor jack LOL.
Old Feb 16, 2007 | 10:51 AM
Disco_Mike's Avatar
Disco_Mike
well, keep me informed.
Old Feb 16, 2007 | 12:41 PM
TopCat's Avatar
TopCat
I have 6 jack stands.... and a floor jack, and wood "ramps" to drive up on to get high enough to get the jack under the car.... and Rhino ramps if your car will fit up those.
It doesn't look like you have to get the car near as high as a C5 to install the system, but according to Borla you have to remove the H-pipe to do a catback installation. Make sure you've got good penetrating oil to lubricate all the nuts and bolts.... would be best if you soaked them the night before the install, i.e., get the car up on stands Friday night and then attempt the install on Saturday.
Keeps us updated.... I can at least come by and learn something about the C6's, which would be cool.
Old Feb 16, 2007 | 01:35 PM
DaBo's Avatar
DaBo
They exhaust on the C6 does not come out as "clean" as a C5. You have to remove the front H pipe section as stated above. Still not that difficult (with a lift) but just an additional step.
I would offer my services and lift but I am a little far away.
FWIW I did attend Littleton High in 81/82.
Good luck with the install.
David
To Help with axle back install?
