Mountain - Prairie Colorado | Kansas | Montana | North Dakota | Nebraska | South Dakota | Utah | Wyoming
The Tear Down................
Old May 27, 2007 | 01:09 AM
C4Fanatic's Avatar
C4Fanatic
Default The Tear Down................
Or, how I spent my Saturday evening:
Up on jackstands ready for the fun to begin
Making progress, so far nothing out of the ordinary found
Getting there, still no parts or chunks found
OK, now I'm stumped, down to here and I have found NOTHING out of the ordinary
I really expected to find a broken valve spring or a lifter with a torn up roller tip, but nothing, nada, zip, zilch
I guess tomorrow the heads will come off, and I'll go from there. Checked all the auxilliaries, no bad bearings or grinding noises internally. If the top end of the cylinders look good, I guess I'll drain the oil and drop the pan.
Old May 27, 2007 | 02:49 AM
Chance's Avatar
Chance
From: I was a young troubadour when I rode in on a song, and I'll be an old troubadour when I'm gone.
St. Jude Donor '08
Hmmmm....
I'm no mechanic, but I'd have thought you would've found something bad by now.
She did not sound good at the track.
Old May 27, 2007 | 10:37 AM
1979toy's Avatar
1979toy
Check the lifters for vertical movenment of the roller on the shaft
.. Check the ends of the pushrods for hammering, it will be slight if it just started .. Look at the lifters to see if one of them is colapsed .. Push on the springs to see if one is broken where it can't be seen .. Put a straight edge across the valve stems to see if they are all at about the same height .. Check the fan blades for interferance (I know that it's kinda late to find that one) .. Take the belt off and check all of the pulleys and the idler .. Good luck with finding your problem.
Old May 27, 2007 | 12:29 PM
C4Fanatic's Avatar
C4Fanatic
And it sounded even worse yesterday when I started it to get it situated in the garage. Sounded like dry metal on metal.
Looked all the rocker arms over, all the pushrods look fine, none of the lifters show a problem, the rollers on each lifter spin free, and none of them are damaged. Looked down each lifter passage at the cam lobe and didn't see any damage. I'm at a loss right now. Going to get the bro-in-law over to see what he thinks.
Old May 27, 2007 | 01:29 PM
Chance's Avatar
Chance
St. Jude Donor '08
Good thing you have those bicycles hanging on the wall there in your garage.
Ya might want to get them down and service them to be sure they're ready to go.
Old May 27, 2007 | 07:00 PM
1979toy's Avatar
1979toy
Do the LT engines have a cam chain tensioner?
I've had piston skirts break but the sound was not like bare metal on bare metal.
Go back and check those belt driven items.
If it happened on start up then you may want to disconnect the starter and see if it was hanging up too.
Old May 27, 2007 | 09:09 PM
C4Fanatic's Avatar
C4Fanatic
This car is still an L98. BIL and I were talking, he's thinking I may have spun a bearing, mainly because, the car died coming home when it was hot, and wouldn't turn over or restart. Once it cooled down the next morning, it fired up. We'll find out tomorrow, I'm draining the oil and pulling the pan. Been lazy today watching Indy 500, F1 Monaco and Coca Cola 600.
Old May 27, 2007 | 11:35 PM
Lionsden's Avatar
Lionsden
Ouch What happened?
Old May 27, 2007 | 11:54 PM
C4Fanatic's Avatar
C4Fanatic
Drag racing with your kid Friday night................
Third pass I decided to drive through the waterbox and make some smoke, dropped it into first, instead of second and think I may have over-revved it a bit.
Old May 27, 2007 | 11:58 PM
Chance's Avatar
Chance
St. Jude Donor '08
Sad thing is that even with the hurt motor.... he still ran quicker than me.
But I know you have some good go-fast parts laying around.... so you should have her better than new before long, right?
Also, if you've got any more pictures of all of our cars together or on the track, I'd love to see them.
Old May 28, 2007 | 10:31 AM
C4Fanatic's Avatar
C4Fanatic
Nick didn't take that many pics, here's one of you.
And here's one of Jim and I
Old May 28, 2007 | 12:19 PM
Chance's Avatar
Chance
St. Jude Donor '08
Old May 28, 2007 | 01:56 PM
1979toy's Avatar
1979toy
The car in the near lane got out on you by more than a car length Chance?
Old May 28, 2007 | 02:24 PM
Chance's Avatar
Chance
St. Jude Donor '08
Hey!! That was a solo run.
Actually, he's probably ahead by more than one length.
I need a lot of practice launching the 4-speed.
My reaction times were never good with my automatic... and they're worse with my new car.
But hopefully I can get back to the track soon for some more practice.
Old May 28, 2007 | 02:56 PM
1979toy's Avatar
1979toy
Every stop light is an opportunity to practice a pro tree launch.
Old May 28, 2007 | 11:10 PM
WydGlydJim's Avatar
WydGlydJim
This must have been before the green dropped, cuz that was the only time it was that close!
Old May 28, 2007 | 11:49 PM
Zr1 Destroyer's Avatar
Zr1 Destroyer
From: Thornton,Co. Press 1 to Proceed in English or 2 for Deportation ...don't let the fence hit you in the azz!
Quasar.....the color says it all, are you driving that beast up to vettes on rockies this year.
To The Tear Down................
Old May 29, 2007 | 02:12 AM
shepsvettes's Avatar
shepsvettes
Default times
James, What did you run with the Z? Still need to get my 93 out again with the nitrous
Old May 29, 2007 | 02:20 AM
Chance's Avatar
Chance
St. Jude Donor '08
I saw Jim run in the 13.3x range at about 107 mph.
Not sure if that was his best time or not, though.
He also lost in the gambler's race on an -.008 red light.
Old May 29, 2007 | 08:05 AM
WydGlydJim's Avatar
WydGlydJim
It'll be there!
13.27 best e.t. 109 best mph........track wasn't hooking too well. I think the best '60 ft was 2.19
on the -.008 red light. I had the guy too he broke out!
