Under medium braking the pedal pulses like the anti lock brake system is engaged. I bled the brakes and the fluid was pretty dirty, maybe I did not get all the dirty fluid out?
warped rotors OR brake pad build-up on the rotors comes to mind. If they have some meat on them, you an turn the rotors and they should be fine.
another trick is to REALLY put some heat into them, then drive slowly back home WITHOUT using the brakes and let them cool overnight.
If neither works. It looks like you need new rings.....if they are 2 piece rotors. Otherwise, you will need a new pair of front rootrs.
