NortheastConnecticut | Delaware | Maine | Maryland | Massachusetts | Martyrdom | New Hampshire | New Jersey | New York | Pennsylvania | Rhode Island | Vermont | West Virginia
I see a bagel run for the guys at ECS is coming up. From what I was told Marc really slows down when the bagels arrive (I fed them crack to get my stuff done on time)....
I am going to be the naive one and actually believe Chris' word on having not only Friday but Friday am. I need to beat the shore traffic in my newly modded beast!
Ok so what are they doing to your car? Cam and Heads? would be my guess since it is taking a week to complete.
LG Mototsports G5X3 cam on a 114 lsa
Comp 921 springs
Titanium retainers
ASP under drive pulley
2 new belts
160 degree thermostat
Taylor plug wire
NGK plugs
Ported oil pump
Ported throttle body
Double roller timing chain
ECS Custom dyno tuning
I know you are looking for 400+ RWHP.
My guess with stock gears on a MN6 you will be around 405 range. Give or take a few. My only reasoning for this is that with my setup I pulled 443 RWHP, but I have the AFR heads with 4.10 gears. If I did not have the 4.10 gears then I would have seen about 455 rwhp. Assuming that AFRs are giving 50 rwhp then you should end up at 405.
though I have to admit it is all guessing work to me and I would not be surprised to see 390 range. EG with his stock gears on an A4 pulled 387 rwhp with the same size cam. His though was a conservative tune.
either way you ar going to love the power. At first you will think what the heck did I get in to because the car runs different than stock, but that feeling goes away quickly. right now I feel as if my car is just stock with a few extra ponies (oh and some added sound)...
Have fun with it. remember there is no break in period with a new cam. Just let it warm up accordingly or you could break a spring....
