Northeast Connecticut | Delaware | Maine | Maryland | Massachusetts | Martyrdom | New Hampshire | New Jersey | New York | Pennsylvania | Rhode Island | Vermont | West Virginia
Corsa exhaust install
Old Mar 17, 2006 | 11:39 AM
patrickC5's Avatar
patrickC5
Default Corsa exhaust install
Hey guys I was currious as to how high you really need to jack the back of your car up to install a cat back? I just got my new/used exhaust in today and want to put it on myself but have no lift. I know that one of the sides either driver or passenger is a little bit of a pain and you must twist so much that you must raise the back of the car pretty high. So I should put wood blocks on my jack and then raise the car up and implace jack stands but will I need wood for the jack stands to? Thanks for any insight guys,
Patrick
Old Mar 17, 2006 | 11:47 AM
sgreen4067's Avatar
sgreen4067
Patrick
pass. side is the pain , must get it up very high,
Old Mar 17, 2006 | 01:07 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
Just cut the pipes off on the stock one, it is worthless and then you don't have to get it that high. The Corsas come in two pieces so you won't have the height issue when you put them back on.
Old Mar 17, 2006 | 04:37 PM
patrickC5's Avatar
patrickC5
Good idea Stehpen I didnt think of cutting off the stock exhaust. I saw that the corsas came in multiple pieces so it shouldnt be to bad I guess thanks guys.
Old Mar 18, 2006 | 08:09 PM
WEF's 95's Avatar
WEF's 95
I had to go 37" to keep from cutting the stock pipes. What a pain. That was 4 years ago and they are still taking up space in the shed. I shudda cut them.
Old Mar 19, 2006 | 09:23 AM
jman1's Avatar
jman1
do all the cat back systems come in 2 pieces?? or just corsa....
Old Mar 19, 2006 | 10:02 AM
RPOZ4Z's Avatar
RPOZ4Z
I cut my old exhaust off when I installed the Corsa Indys.
Old Mar 19, 2006 | 10:15 AM
Humanoid 2.0
Most aftermarket systems that I know of come in 2 pieces. It makes it easier to ship them, so I think that is why they may do that.
To Corsa exhaust install
