NortheastConnecticut | Delaware | Maine | Maryland | Massachusetts | Martyrdom | New Hampshire | New Jersey | New York | Pennsylvania | Rhode Island | Vermont | West Virginia
All the way up the Veter clears with tons of room. Ordered the BUB in August at Corvette Car lisle and received it 2 months later. It is the standard 7000 Pound BUB. Takes a minimum of four guys to assemble and took us about 3.5 hours. Even with four guys those ramps are a bitch. They are freaking heavy, especially the one that contains the hydraulics and cables.
Looks great which model BYB did you get? How long did it take to arrive once you ordered it? Was it hard to assemble?..... and a dozen other annoying questions.
I just ordered a BYB a few weeks ago. Mine should arrive before Christmas.
Looks good I will have to come check it out. Did you get the plasma in
the garage yet.
Mike
Just let me know your oil and oil filter preference cause I want you to be happy. You just sit back and relax and I will take care of the rest. The Plasma is mounted on the wall above the work bench next to the keg refrigerator.
I was thinking plasma cutter, forgot about the TV's
Looks great. How do you do wheel and brake work with this lift? For instance, if you wanted to change out your brake pads, is there a way to support the car off the wheels?
