****Barroom Blitz****[Bar]
Mar 17, 2007 | 01:23 AM
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
So i got the first peice of a new Corvette colectable today, i have no place to put it so it will stay in the box
http://www.collectiblestoday.com/ct/...rvette&abbr=hw
Quote:
Originally Posted by
Mr Mojo
I'm getting close to the age where I don't want to crawl under the car anymore.
Unless you're meeting a girl with a wrench right?
Mar 17, 2007 | 01:24 AM
Already a quarter of the way through this bar....holy crap...
From: Probably talking that police officer out of giving you a summons! ========== The Beautiful Lower Hudson Valley, NY
St. Jude Donor '08-'09
Mr Mojo
I forgot, you weren't here when I posted my latest garage pics.
So what are you saying? You can't put a lift in there?
Charlie
Mar 17, 2007 | 01:26 AM
Mr Mojo
Dude clean your garage , thats worse then mine
Mar 17, 2007 | 01:27 AM
sasnglass77
Mar 17, 2007 | 01:28 AM
MR1911
The first pic is the "after" shot, the other is the "before"
So it is clean!
jersey jay
BENZ!!!!!!!!!!!
I'm torn between a few models.
Is the CLS63 AMG on your short list??
Charlie
Mar 17, 2007 | 01:29 AM
St. Jude Donor '03 through '17
MR1911
JJ where did you mount the ballast ?
We mounted them on the wheel wells right under the head lights. You have to take over the light covers and then the black trim piece around the headlight housing. Then you have two remove 2 screws so the light will flip down or up which makes it easy to mount the ballast as well as put in the new HID projector housing and remove the stock one. It's all wired and was working but I have a bad bulb e if it gor ballast. It worked one day and then the next day I detailed the car and it stopped on the drivers side. I was able to check it out and the top of the ballast felt wet so I'm not shure if it got inside. All my blade fuses are good and you can hear the relays pull in when you turn the lights on so it's either the HID bulb or ballast, simple fix.
St. Jude Donor '07-'08
Humanoid 2.0
that's really cool Stephen - I'm gonna havta get me one of those
Mar 17, 2007 | 01:30 AM
Mr Mojo
So it is clean!
So you did clean it out!! GOOD FOR YOU!! That garage was a tragedy waiting to happen
Mar 17, 2007 | 01:31 AM
