NortheastConnecticut | Delaware | Maine | Maryland | Massachusetts | Martyrdom | New Hampshire | New Jersey | New York | Pennsylvania | Rhode Island | Vermont | West Virginia
So I ordered up some LED reverse bulbs and they sent me the wrong ones. I tired them out but I want to try the ones I ordered. I may get the clear hosing as well after I test out the LEDs I wanted.
The ones they sent me were more money too:
1 Super High Powered 3 Watt Wide Angle Flux Forward Facing Led
10 Side Facing Wide Angle High Powered LEDS
But i wanted the Wide-Angle 180 degrees High-Powered 3 Watt Luxeon Led The most powerful led made.
Here is a comparison. The incandescent stock on the left, the LED they sent me on the right. The incandescent is brighter. I do like how the LEDs color looks, especially with my blue paint. I will also be replacing the tag lights as well with LEDs.
My rear is just fine thanks! The rear wasn't the problem with the car. It was the tranny.......it's almost done. Entire trans has been overhauled with hardened gears, roller bearings a larger pump, new valve body and a few other things........plus a nice new custom made torque converter
How much if you don't mind me asking is that gonna set you back?
The rest of my body, however is in sad shape today......I chopped and moved and inch and a half of ice from the driveway and walkway - there's not a muscle in my body right now that's not screaming out in pain
A little over $3000 - also includes a new crank pully, heavy duty clutch pack blah blah blah......but it should make it pretty much bullet proof and the added torque should have a neck snapping effect........just what I need, more torque
