Northeast Connecticut | Delaware | Maine | Maryland | Massachusetts | Martyrdom | New Hampshire | New Jersey | New York | Pennsylvania | Rhode Island | Vermont | West Virginia
NJ Inspection Question...
Old Aug 5, 2007 | 01:17 PM
Byter's Avatar
Byter
Default NJ Inspection Question...
Sorry if this is the wrong forum. I'll repost in Tech if it's a problem. However, I have a bad tire pressure sensor. Is the warning it displays in the DIC enough to fail NJ inspection? Thanks...
Old Aug 5, 2007 | 02:55 PM
zaragoza's Avatar
zaragoza
Veteran: Coast Guard
St. Jude Donor '07 thru '14, '24
As I understand ANY warning on the DIC will be cause for failure.
Old Aug 5, 2007 | 07:32 PM
98NYFINESTVETTE's Avatar
98NYFINESTVETTE
From: 10.70 @ 124mph, Stock Bottom End @ 3620lbs, ECS Racing Team Member. The 1st NMCA LSX Index Rumble World Champion. 2011,12,13 Champion
You will not fail inspection because this is not a problem in the computer (Stored code). Your vehicle will not go on a dyno, They will plug into your vehicle. This sensor does not send a code to the computer. Your sensor is not a safety issue to were the vehicle would fail. I have knowledge and experience in NJ inspections.
Old Aug 6, 2007 | 07:56 AM
Redvette_22's Avatar
Redvette_22
Its not a problem, just keep it clear with the reset button. If you want, you can let the "person" who is going to sit in the car that a tire sensor battery is dead and the message sometimes comes up. That is what I did and they had no problems passing the car.
Old Aug 6, 2007 | 04:47 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
You're being too kind...it's not a "person" at DMV....more like a troll (and that's being polite!)
Old Aug 7, 2007 | 06:50 PM
Byter's Avatar
Byter
Thanks guys, that's good to know. BTW, it's a private inspection (the guy who does all my wheel and tire work), so he's cool. It's worth the $75 not to deal with DMV!
To NJ Inspection Question...
