Northeast Connecticut | Delaware | Maine | Maryland | Massachusetts | Martyrdom | New Hampshire | New Jersey | New York | Pennsylvania | Rhode Island | Vermont | West Virginia
help me you guys.....
Old Nov 4, 2001 | 11:47 AM
QuickVet's Avatar
QuickVet
Default help me you guys.....
Ok, a little while ago i posted that it feels like my car is running out of gas on the top end of the track. i recently mounted an external fuel gauge so i can watch the fuel presure as i race the car. today i tested it out!
i have the fuel presure regulator up to 8psi. i launched the car at 2000 rpm and shift into first at 6000. then by the time the car gets to 6000 rpm in second gear, the fuel pressure it at 2 psi. i havent tried third gear yet because i was testing it on some backroads near my house.
2psi at 6000 rpm cant be good, right? what should i do know? i have an aftermarket Carter Strip fuel pump that is good for 9 psi. do you think i need to replace my pump?
thanks for any advice.
Old Nov 4, 2001 | 12:49 PM
BLISS's Avatar
BLISS
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: help me you guys..... (Vetteboy)
Paging : Mike69
Old Nov 4, 2001 | 01:54 PM
Gordonm's Avatar
Gordonm
Default Re: help me you guys..... (z06bliss)
Check my post on the C3 section on this topic. sounds like restriction before the pump
Old Nov 4, 2001 | 03:22 PM
QuickVet's Avatar
QuickVet
Default Re: help me you guys..... (Gordonm)
seems to be only dropping pressure that much when the motor is hot. does that mean vapor lock?
To help me you guys.....
