Northeast Connecticut | Delaware | Maine | Maryland | Massachusetts | Martyrdom | New Hampshire | New Jersey | New York | Pennsylvania | Rhode Island | Vermont | West Virginia
60' stinks.
Old Nov 27, 2001 | 10:25 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Default 60' stinks.
Anyone got an idea why my 60' is so slow??????
Last year I 60' 1.70s this year with 100 more HP I only 60'ed 1.60.
thats only a .10 better in 60' but my ET went down went down .88.
I don't think the 3000 vigilante is enough?
Old Nov 27, 2001 | 10:51 PM
QuickVet's Avatar
QuickVet
Default Re: 60' stinks. (mackeyred96)
i dont know but your car is pretty slow. if i were you i wouldnt expect much more then that in your 60' with such a crappy quarter mile time ;)
seriously though, what tires are you using? mabey you need all out slicks if you dont already have em :D
Old Nov 27, 2001 | 11:02 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: 60' stinks. (Vetteboy)
maybe you should let Panuzzo drive.. :lol: :lol: :lol:
Old Nov 27, 2001 | 11:08 PM
69shark's Avatar
69shark
From: Godspeed Mikey Hogsmak Invitational Spring Skyline Drive Corvette Cruise
Cruise-In I Veteran
Default Re: 60' stinks. (CHRIS NJ C5)
:eek: :eek:
Old Nov 27, 2001 | 11:47 PM
BLISS's Avatar
BLISS
Yeah that sucks John, even I could do better with my piece of crap pickup truck that has 190 HP ! :lol: :lol:
Old Nov 28, 2001 | 12:16 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Well John, you also got to remember all the other changes you made.
17" 275 drag radials to 15" rims and 325's. Different shocks, then you went to the ET streets, the gear change, Aren't the ET streets a smaller diameter than the last set of drag radials?
Also didn't you ask for a looser converter? Would that make that much of a difference?
Old Nov 28, 2001 | 12:39 AM
1996LT1's Avatar
1996LT1
Default Re: 60' stinks. (Mr Mojo)
Perhaps you didn't pick up much power in the low end....or maybe even lost a tiny bit at the absolute lowest "operating" R's in 1st gear? You did pick up a whole bunch mid & top end. That "package" is a winner in my book & may find it's way into one of my cars soon :)
1.60 ain't exactly BAD fella........but being a 1.6"0" I know you must want to see 1.5's as bad as I wanted to see 1.7's after my string of 1.80's
I would also bet if you had your Drag Radials on (instead of the E.T. Streets)the day you ran your .58 it would have been low 50's or high 40's. The air was really really good that day & you only picked up .04 from your previous best.
Maybe when the trans is out you can get the converter redone? maybe around 3500 & see what happens to your 60' times. Whats the S.T.R. in that converter you have?
:D Or is this just a post to "get" JP since he can't go 1.60??? :D
Joe (aka "Mr. Runner-Up")
Old Nov 28, 2001 | 10:07 PM
jpee's Avatar
jpee
Default Re: 60' stinks. (1996LT1)
Joe..
I have 60' in 1.68...ONE time, my daughter also did a 1.68... & i have a bunch of 1.69s...
I want 1.59 now... I also want to drive a Top Fuel car... I doubt I'll ever see either one.. :(
Old Nov 28, 2001 | 10:41 PM
mackeyred96
Joe I'm want to go to a 4400 convertor with a lock up switch, and I'm looking at a REAL rear gear (Hows 4.88 sound) and then using a 30" tire.
I know I've got enough power to 60' low 1.4. Now I've just got to get it out of the car. Hows 4.88 sound.
Old Nov 28, 2001 | 10:58 PM
Mr Mojo's Avatar
Mr Mojo
Hows 4.88 sound.
Like this: WAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAA!!!!!!!!!!!!!!!!!!
Old Nov 28, 2001 | 11:22 PM
mackeyred96
Hows 4.88 sound.
:yesnod: :yesnod: :yesnod: :yesnod:
Old Nov 29, 2001 | 12:04 AM
QuickVet's Avatar
QuickVet
that will do the trick :yesnod:
Old Nov 29, 2001 | 02:06 AM
1996LT1's Avatar
1996LT1
Now youre talkin' !!! :D :D I didn't think you wanted to get quite that radical with the big baloon's but I like it !!! That will raise your "overall" ratio about +.35 numerically & give a heck of a kick in the pants no doubt :cool:
Old Nov 29, 2001 | 09:48 AM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
Hit the nitruous from the starting line.
Kidding.
When you order then 4.88's you probably want to order a Trailer too:)
Old Nov 29, 2001 | 11:12 AM
ralph's Avatar
ralph
John, i have the same problem...only worse. You are short timing about .05-.07 quicker than me. My converter is a tight 2800 and i was going to have it loosened about 300 rpms, BUT....i aslo currently have a traction problem, so that would only make things worse for me. On a Sunday (or any other track) i can hook consistently, but duiring the etown street tire fests, i think you could slip and fall on your butt at the starting line...LOL!!! My plan is to do some chassis tuning first, then maybe loosen the converter. Been doing some reading on chassis set up and developing a plan of action.
I'm with you though, i think we should be short'n high 1.5s to low 1.6s (in heat). Friggn JP is shorting almost the same as me....and he's still using the original oil for christ sake!!!
If you go to a 4000+ stall & more gear, you should easily see low 1.5s even high 1.4s IF (big IF) you can hook up. i guess you are willing to give up a lot of streetability...i'm not there yet.
Good luck...we should compare notes at some point.
[Modified by ralph, 9:14 AM 11/29/2001]
Old Nov 29, 2001 | 08:58 PM
mackeyred96
Default Re: 60' stinks. (ralph)
Driveability :confused:
All I need is 23 miles to E-town from my house for the next year.
Old Nov 29, 2001 | 09:12 PM
J Z06's Avatar
J Z06
Talk about PURPOSE BUILT !! :)
To 60' stinks.
Old Nov 29, 2001 | 09:29 PM
QuickVet's Avatar
QuickVet
Default Re: 60' stinks. (JD 90 383)
mackey, what do you think you will run with these mods?
will you ever be satisfied? :lol:
Old Nov 29, 2001 | 10:10 PM
mackeyred96
I've been racing since 1967 and i'm not satisfied yet.
Old Nov 30, 2001 | 08:19 PM
mackeyred96
:yesnod: :yesnod: :yesnod: :yesnod: :yesnod: :yesnod:
