Northeast Connecticut | Delaware | Maine | Maryland | Massachusetts | Martyrdom | New Hampshire | New Jersey | New York | Pennsylvania | Rhode Island | Vermont | West Virginia
Failed NJ Inspection
Old Feb 25, 2008 | 06:19 PM
XCLR8TN's Avatar
XCLR8TN
Default Failed NJ Inspection
Not for the headers, not for the empty cats not for any codes. The car failed because the turn signals blink too fast. I kid you not, they failed the car because the turn signals blink more than 50 to 130 flashes per second. This State Inspection is a JOKE!!! We were out in the garage timing the flashes and it's about 2 flashes a second.
Old Feb 25, 2008 | 06:22 PM
BrooklynC6's Avatar
BrooklynC6
aka allbottle¬hrottle
From: Brooklyn New York The DVL and the chicken sleep with the fishes....
St. Jude Donor '08
Old Feb 25, 2008 | 06:46 PM
EPMM 03 C5's Avatar
EPMM 03 C5
that's the great state of new jersey for ya!!
eric
Old Feb 25, 2008 | 07:49 PM
TC-Vette's Avatar
TC-Vette
St. Jude Donor '08
So the inspection station said it flashed > 50/second, but you timed it in the parking lot at ~ 2/second?
Can you watch as they inspect your car in NJ - cuz it sound like it's some sort of mistake on the part of the inspector.
The only reasonable way I could see it happening that way would be if you had a loose bulb. When a bulb is loose (or broken) it creates less draw on the relay which means the turn-signal relay cycles faster. If a bulb was loose it might have been fast-cycling in the inspection garage, but then seated itself properly as they drove it out so it flashes at normal speed.
Old Feb 25, 2008 | 07:59 PM
XCLR8TN's Avatar
XCLR8TN
We put LED turn signal lamps in two years ago with about 36 amber Leds per bulb. The resistance is lower with the LED's so it blinks faster. My husband is in a rage. He says it is because these idiots @ the inspection station making minimum wage saw two things, Corvette and Female and decided to have some fun @ my expense.
Old Feb 25, 2008 | 08:38 PM
zaragoza's Avatar
zaragoza
Veteran: Coast Guard
St. Jude Donor '07 thru '14, '24
I failed NJ inspection because I have a R-D Racing cross bar on the vette. The highly trained inspector said that it would be impossible for rescuers to get people out of the car in case of a accident. It took a few phone calls to Trenton and 2 trips back to the inspection station before they finally passed it.
Old Feb 25, 2008 | 09:33 PM
5OBait's Avatar
5OBait
They have to keep the stations busy so the station can meet the quota to get more funding and the jacka.. state workers can keep their jobs and get raises and bring their relatives on board. This state is so fubar its not even a joke any more. Most things that happen in this state go directly against and completely ignore the constitution.
Old Feb 25, 2008 | 10:28 PM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
I saw that I was past due on my inspection by several months. Took it last month.
Was prepared to hand over all my paperwork when I found out I had an expired insurance card. I knew I was going to be failed because that's a big .
Guess what, they never blinked an eye and passed me anyway. Go figure.....
As for the lights, you can try adding a resistor in series to up the resistance. Take it out when done. The other potential option, that I've used in other cars, but don't know if it's available for the vette is a Heavy Duty flasher. The HD flasher is meant to work with bulbs that have a lower resistance, and flashes slower.
Old Feb 25, 2008 | 10:51 PM
Ralphyboy's Avatar
Ralphyboy
St. Jude Donor '08-'09
The "state inspection" stations are not state run, but they are subcontractors who are morons. I sat in a line for almost two hours to get my DD truck inspected with only 3 cars in front of me. Yes, 3 cars.I was in the wrong line. One of the inspectors said that for my year truck, I was supposed to be in another line. When the " manager "came strolling out to look at the mess, I got out of my truck, asked him what was going on, and he just said he'd look into it, and then started to call someone on his cell phone and walked away. I won't go back, and I especially won't let one of those imbeciles touch my vette.
Old Feb 25, 2008 | 11:28 PM
C6 DVL's Avatar
C6 DVL
St. Jude Donor '08
daam.........
I had L.E.D.s for my turn signals, they flash fast cause the flasher is not getting enough voltage and it thinks one bulb is out thats why they flash fast, I had L.E.D's for my brake lights as well (c5 w/ euro lenses (brake/turn split) well, those L.E.D.s screwed up my active handling. the body comp uses the brake lights as an input to control A/H
Old Feb 26, 2008 | 06:30 AM
hollyt's Avatar
hollyt
St. Jude Donor '08-'09-'10-'11-'12-'13
I got a Flasher Bypass Harness to eliminate Hyper-Flash
http://www.corvette-enhancements.com/
I do not find it on there site but I bought it from them and it works GREAT!!
Old Feb 26, 2008 | 09:14 AM
nickolbag's Avatar
nickolbag
Thats lame, I drive right thru a state inspection station with that bar and they didn't say a word.
Old Feb 26, 2008 | 12:12 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
I spliced mine in, it looks like a vendor finally got a plug and play set up. That is the way to go and not play around with resistors.
Old Feb 26, 2008 | 01:24 PM
RPOZ51's Avatar
RPOZ51
From: For the strength of the pack is the wolf . . . . . . and the strength of the wolf is the pack.
New Jersey, You Gotta Leave It.
I won't bore you with my story, but it's equally stupid.
Unless I'm in the mood to argue with a low level functionary, who only knows what is in his SOP, I'd rather pay a few bucks and go to a private inspector, and spare myself the aggravation.
Old Feb 26, 2008 | 01:32 PM
cfl70's Avatar
cfl70
Veteran: Marine Corps
just bribe the state run employee like everyone else does and then you will pass
Old Feb 26, 2008 | 08:24 PM
It'sHerVette!'s Avatar
It'sHerVette!
St. Jude Donor '07 thru '25
I go to Westfield with an appointment. Never have to wait more than a couple of minutes. Only failed one vehicle once and it was legit. They even passed my motor home with water in the front turn signal housing several times running. The appointment system is the best.
Old Feb 26, 2008 | 08:25 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
Excellent! Thanks Holly, this went into the bookmarks.
NJ Inspection just failed the Wife's Fiero GT for power steering? (They don't have power steering). And the power window didn't go up and down fast enough for them.
To Failed NJ Inspection
Old Feb 26, 2008 | 09:53 PM
Marc V.'s Avatar
Marc V.
Living in NJ is like
Thanks for the stories
Old Feb 26, 2008 | 10:08 PM
dvilin's Avatar
dvilin
Old Feb 27, 2008 | 01:41 AM
Wolfgang427's Avatar
Wolfgang427
I did that with out knowing it. The inspector(thief) made off with all my change from the console. Apprantly their wages aren't enough that they have to steal loose change from unkowning victims. Came back to complain to manager, complaint fell on deaf ears.
