Northeast Connecticut | Delaware | Maine | Maryland | Massachusetts | Martyrdom | New Hampshire | New Jersey | New York | Pennsylvania | Rhode Island | Vermont | West Virginia
STRIP TEASE!!
Old Dec 22, 2001 | 02:54 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
Default STRIP TEASE!!
well guys, this mornin i started strippin the 69. No sanding, no stripper, jus one razor blade.. only took 1 hour to hit one door down to bare glass.. not bad time wise.. if I keep at it i should have my car ready to paint in about a week :eek: :eek: :eek:
Old Dec 22, 2001 | 03:04 PM
scorp508's Avatar
scorp508
Default Re: STRIP TEASE!! (Corzvette69)
ONE blade? Thats it?
Glutten for punishment?
Old Dec 22, 2001 | 03:35 PM
QuickVet's Avatar
QuickVet
Default Re: STRIP TEASE!! (scorp508)
have you done this before? you know, to other peoples cars :p:
Old Dec 22, 2001 | 07:47 PM
boweryboy's Avatar
boweryboy
Cruise-In II Veteran
Good Luck! :flag
Old Dec 22, 2001 | 08:13 PM
nu2gm's Avatar
nu2gm
Curious? Why scraping with a razor blade? Does this keep the panel flat and not damage the glass as sanding would? Will you be using filler before painting? Keep us posted as the job progresses. :lol:
Old Dec 22, 2001 | 11:14 PM
Corz's Avatar
Corz
Default Re: STRIP TEASE!! (nu2gm)
Scorp, i mig welded 18 blades together so i could do one massive swipe down the entire car. :smash:
I work in a body shop and I've done this sort of thing before. Only kind of paint you can do this on and get away with is laquer. And with the car only having one coat of laquer on the car (and not 15 other colors hiding) it is easy. No goudging of the glass at all, as long as you have the blade angled right. I did put a couple scrapes in it (trying to start on a bad spot), but nothing that some good ol spot puddy cant fix.. Tomorrow i hope to get the 1/4 panel and decklid stripped, and then i have till January 2nd to get the car ready for paint.. :jester
[Modified by Corzvette69, 10:15 PM 12/22/2001]
Old Dec 22, 2001 | 11:47 PM
pkmoose's Avatar
pkmoose
Cruise-In III Veteran
sounds like fun :rolleyes: :rolleyes: good luck :)
Old Dec 23, 2001 | 12:27 AM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
At that rate you just get the car finished before your first social security check.
Old Dec 23, 2001 | 02:42 AM
C5_PIG's Avatar
C5_PIG
Default Re: STRIP TEASE!! (mackeyred96)
Damn thats too long. Hey Bill is your sig LOOOOOONG enough?
Old Dec 23, 2001 | 08:54 AM
Mike69@ECS's Avatar
0Mike69@ECS
Former Vendor
Cruise-In V Veteran
Sounds Good Corey! You have guts! I dont think I could go at my car like that with a blade. When I do it I'm going to go the Chemical route. Good Luck and keep workin!
Old Dec 23, 2001 | 02:15 PM
Corz's Avatar
Corz
Default Re: STRIP TEASE!! (Mike69)
i thought about the chemical route but its too messy and it smells aweful. Once i get the paint off, I'll block sand the lacquer primer and go over it with a urethane primer. wetsand the hell out of it and hope for the best..
Electron Blue.. here i come
To STRIP TEASE!!
