Northeast Connecticut | Delaware | Maine | Maryland | Massachusetts | Martyrdom | New Hampshire | New Jersey | New York | Pennsylvania | Rhode Island | Vermont | West Virginia
Lowering C5
Old Oct 16, 2008 | 01:24 PM
sscamaro's Avatar
sscamaro
St. Jude Donor '07
Default Lowering C5
I have a friend with a C5 and wants to get it lowered. Is there anyone in the Reading,PA area that has the experience do this?
Old Oct 16, 2008 | 02:02 PM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
I charge 100 bucks to lower them. Tell him to give me a call if he is interested.
Old Oct 17, 2008 | 12:46 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Lowering a C5 is very easy. <=====
Old Oct 17, 2008 | 08:35 PM
PA Z06's Avatar
PA Z06
Originally Posted by Glennm27
It is pretty easy Ralph, just make sure you get it aligned eventually
Old Oct 17, 2008 | 09:41 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
FE1 (base suspension) goes down well on stock bolts. Z51 doesn't go down much and is just a tease. JMHO.
Old Oct 18, 2008 | 10:46 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
it will take about 3 minutes to lower the rear
If it's a low mi/no rain car, about 5 minutes front
jacking the spring to release tension?? maybe 10 minutes
PB Blaster soak on the front adjuster for most of the C5's
use only a 6pt 10mm wrench up front, most hacks will strip them in a minute
To Lowering C5
