NortheastConnecticut | Delaware | Maine | Maryland | Massachusetts | Martyrdom | New Hampshire | New Jersey | New York | Pennsylvania | Rhode Island | Vermont | West Virginia
I use tire depot in Bristol, only talk to the owner Tony, and Bring that 249 bravo to communicate the care to be taken. Personally though I always bring the wheels instead of dropping off the car - I don't let any tire shop touch my car. -Dan
St. Jude Donor '11-'12-'13-'14-'15-'16-'17,'20, '21,'22, '23
I was happy with the work done by Tires International in Manchester. They use to be on broad st. right next to J & M motorsport that did alot of corvette work. J & M would send the cars to Tires International whenever tire/wheel work was needed, so the people at Tires International are very familiar with corvettes.
I dealt with Dale.
Not Farminington Valley but just in case you can venture further out.
steve, if your ever in ne ct...there is a local guy (also the one building a 1000 hp twin turbo gtm) he has a shop that does big dollar wheels ($4000 and up ) on every custom car/truck in the area, every one is perfect! no scratches, marks of any kind...altered image customs- speak with josh (860) 564-5667
I've used Tire Depot a couple times, with no problems. They are a Tire Rack Installer. I also bring just the rims and tires.
No matter where you go, make sure they know exactly what you want done. If you want the stick on wheel weights make sure they know that and emphasis no clip on weights. I wait for the rims, and check the first one, so they can't screw up more than one.
Not central, but Paul Minore at our shop does high end wheels all the time. If you can't find anybody you trust, I know he can do them without a problem. He is not in today, but I can make the appointment for you, or you could call Monday.
Rick
From: kent ct - "if i'm not in the vette, i damn well better be on the yacht."
St. Jude Donor '13
Hi, Steve; I've used Zeller in Torrington many times. No-touch mounting and they care.....68sixspeed has it right! take the wheels, not the car!! See ya. Dave. (starting my garage project...)
Just put new GY's on my speedlines. No marks & perfectly balanced. Using them for years mounting tires from the tire rack on my 89 and other cars. No disappointments and reasonable $.
