NortheastConnecticut | Delaware | Maine | Maryland | Massachusetts | Martyrdom | New Hampshire | New Jersey | New York | Pennsylvania | Rhode Island | Vermont | West Virginia
OK, I've stopped dreaming of a ZR1......it's time to do get back to reality. :nonod: :sad: I need to replace trailing arms, and I think I'd like to do the whole ball of wax, arms, bearings, rotors etc. Where do I start? :confused:
From: Godspeed Mikey Hogsmak Invitational Spring Skyline Drive Corvette Cruise
Cruise-In I Veteran
Cruise-In II Veteran
Re: Trailing arms (SEE3ER)
1965-82 Rebuilt Rear Suspension
Matching numbers & top quality work are important to your Corvette
Choose Bair's to protect your investment
We will professionally rebuild YOUR rear trailing arm to TOP QUALITY
PARTS:
1 Inner Bearing
1 Outer Bearing
1 Inner Race
1 Outer Race
1 Shim & Spacer
1 Inner Seal
1 Outer Seal
1 Inner Dust Shield
1 Castle Nut & Washer
1 Handbrake Cable Guide
1 Handbrake Adjuster
1 Set S.S. Handbrake Springs
1 Anchor Bolt Lock
1 Backing Shield
2 Handbrake Shoes
2 Handbrake Levers
5 Wheel Studs
5 Rotor Rivets
1 Front Trailing Arm Bushing Kit
4 Trailing Arm Studs & Nuts
$299.00
814-683-4223
ORDER LINE ONLY 800-421-9644
3 YEAR GUARANTEE
Unlimited Mileage
LABOR
Complete Inspection of all Parts
Clean & Detail Parts
Check over 30 Spot Welds on Trailing Arm
Rebuild Trailing Arm
Set Up Bearings to GM Specs
Assemble Handbrake Hardware
Check Spindle Support (each year is different)
Recondition Spindle Support
Recondition Spindle Flange
Recondition Caliper Support Braket
Rivet & Machine Rotor to Match Spindle and Remove Run Out
Press Front T-Arm Bushing into Arm
Pack Wheel Bearings with High Quality Grease
Press Together & Torque to GM Specs
Adjust Handbrake
Free Custom Built Shipping Boxes
MATCHING NUMBERS (DATES)
Over 25 Years Experience, Same Location
:rolleyes: Good answer, that should point him in the right direction... :(
Maybe he should contact Avitrix, as she just had the same thing done.. Also I know a shop out here in Somers NY if you want...
They at least can give you a labor charge... as for parts, like I said Avireix just bought the complete set up for her 79 & at least she knows where to get it.. At leats that will be a start..
I think most of us know it will cost a "Fat wad of money ;) but I think you were looking for a more specific answer... E mail me if you need more info..
Thanks for all the responses! :cheers: But if it's a Fat Wad Of $$$, I'll just put it towards that ZR1 I've been wanting. These are not that bad.... :rolleyes: To be continued........
