Northeast Connecticut | Delaware | Maine | Maryland | Massachusetts | Martyrdom | New Hampshire | New Jersey | New York | Pennsylvania | Rhode Island | Vermont | West Virginia
installing rotors myself
Old Apr 9, 2010 | 10:07 AM
MaddChopper's Avatar
MaddChopper
St. Jude Donor '09
Default installing rotors myself
hey guys i just bought a set of (front and rear) slotted and drilled rotors for my 98 vette. I also bought a pair of hawk brake pads (front and rear). ive never done my own rotors before. Is this a job i can do myself? I have changed my front brake pads before but have never done the rears myself. also is there anything i need to know like do i have to bleed any of the lines to do this. Any info would help thanks
Old Apr 9, 2010 | 10:36 AM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
pads and rotors should be pretty easy, at least on my car that hard part was getting the rear rotor off the emergency brake pads.
getting the calipers back on with new pads and rotors might require a c-clamp to compress them, but that should be the hardest part.
never done the entire job, just pulled mine apart to put chrome pad covers on and pull wheels off so the eradispeed rotors get cleaned every few months.
Old Apr 9, 2010 | 05:23 PM
LS3x416's Avatar
LS3x416
Yes it is a DIY project. I learned how to do brakes recently. Make sure you have the right tools.
C-Clamp, Torque Wrench, Jack Stands, etc.
Old Apr 9, 2010 | 05:45 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Hell yeah!!!
Easy swap with 1/2" drive breaker bar or impact
drive to Ct and I'll lend a hand
follow proper torque spec and you will be fine
Old Apr 9, 2010 | 06:55 PM
Liquid1's Avatar
Liquid1
I'd like to drive down and learn as well if I can work it with my schedule.... let me know if you guys get together.
Old Apr 9, 2010 | 08:36 PM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
Easy as pie.
Only "difficult" part is removing caliper mounting brackets from hubs. Get that breaker bar and muscle ready.
Old Apr 10, 2010 | 02:38 PM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
Get one of these, brake caliper spreader, best $10.00 I've ever spent. While you're in there, change your bleeders to speed bleeders, makes bleeding brakes a very simple easy one man job.
To installing rotors myself
